3cx v20
pedro21090
Platinum Distributor
Boa tarde tudo bem?
na versão v20, a opção de provisionar via stun não está mais disponível? apenas por SBC e LOCAL?
Boa tarde tudo bem?
Olá, telefones IP remotos devem estar provisionados por trás do SBC 3CX ou telefone roteador.
Se ainda desejam usar o STUN devem fazê-lo com um modelo customizado
Provisioning a phone with STUN​
If you wish to use STUN, then you must create a custom template. You can then enable STUN in this template and select it when you add an IP Phone for a user.
  1. Go to Advanced > Templates > Phone Templates.
  2. From the dropdown, choose your phone model and copy the template.
  3. Now look for the entry <AllowedNetworkConfig> and do the following;
<option value="LOCALLAN">0</option>
<option value="REMOTESTUN">1</option>
<option value="SBC">0</option>
</AllowedNetworkConfig>
  1. Now go to Add the phone in the users tab
  2. Select the custom template you just created:
  1. If 3CX RPS OFF - You will get a dialog showing the provisioning link you have to enter into the phone, using either DHCP 66 or by logging in to the phone interface.
  2. If 3CX RPS ON - we create a 3CX RPS event and reboot the phone.
We do not recommend using STUN and you will not receive any support from 3CX, either in the forum or via a ticket.
maxcolo
